A while back I had the extreme idle dip a lot of people get. I didn't have any money to fix the real cause, so i just bumped the idle up. Problem is, I had bad info and adjusted the idle stop screw on the throttle valve (the little allen screw) instead of the idle air valve. Now I want to set it back to where it should be, but all of the info I find is for adjusting the idle air screw.
How is the throttle stop screw supposed to be adjusted?
