No problem, there's always a learning curve.
Searching through historical posts here, It could be as simple as a tear in the intake tube or a MAF.
P0171 (bank 1) is usually a complement of P0174 (bank 2). The V6 bank 1 is the right/ US passenger side of the engine.
Here is a sampling of p0171 threads:
1.
post6747598.html?hilit=P0171#p6747598
2.
post6611779.html#p6611779
In the event it's your MAF sensor, here is how you test it:
post6772150.html?hilit=maf#p6772150
Those are some of the documented ones, but this is the list of possible causes from the manual:
- Intake air leaks
- A/F sensor 1
- Fuel injector
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Mass air flow sensor
- Incorrect PCV hose connection
