breadbox »
https://forums.nicoclub.com/breadbox-u49113.html
Fri Feb 08, 2013 9:33 am
Bah drive shaft is the easy part.
There was a member on here with an auto and a paddle shifting setup and drifted the crap out of it. So I am guessing with a better torque converter and a decent auto trans from a KA( which by the way in my area can be found for $100 or less or free from someone doing a 5spd swap, as long as they don't have to lift it into your car they usually don't care. I have a spare just chilling in the corner in case the other one in the koop dies) you could have fun on the cheap.
I want to say they will easily rock 300-330hp and throw it down. I am sure someone makes universal ecu's to control shift points so i am sure the trans could be tuned in that respect as well, or just unplug the rev sensor and shift off the speedo, shifts harder as I remember and was maybe a little peppier when flooring it.
Also why are we bringing another car into the mix? Hondas are more expensive than nissans, I'd probably would buy a $1500 nissan before buying a $1500 honda(which would most likely be a motorcycle).
