Idiot light?
bogart101
Car: 91 300ZX NA Few Mods
guys when i turn on my headlights the red idoiot light for the lights goes on.
I have replaced the 3rd brake light bulb which was out so it doesnt come on when you hit the brakes. All lights and signals work.
Any ideas?
thx.
NolimitZ32
Mine does the same, thing and everything works as it should so I just gave up.
bogart101
anybody?
thx
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
I see you're running the J-spec tails from your avatar picture. If they have the original bulbs in them, they will indicate a different voltage for the tail sensor, and make it think a bulb is out. Solution? Swap with OEM bulbs.
If that doesn't do it, clean the connections on the rest of your TBL bulbs. They're prone to corrosion, and the bulb housing builds up gunk and gives a bad voltage reading to the sensor, indicating a burnt bulb.
If neither of those methods work, the sensor is bad. I've seen a few go bad, but not many. I believe there is a write up somewhere to bypass it, however.
bogart101
Thank you. Ill check all of it out. Much appreciated!
