RobDET »
https://forums.nicoclub.com/robdet-u7114.html
Mon Aug 04, 2003 4:49 pm
they do do this... suspension travel causes changes is toe... thus CV joints are required in all IRS RWD cars... Some real old cars ( i know the old jags for instance) had 2 univeral joints at each end of the shaft. The things in your 240 work in exactially the same way as CV joints on a FWD car they just change angle to a lesser degree. Also when the car is at the bottom of it's suspension travel or the top there is angle to be worked out. They are CV's man.
here's a quote from a tech website
"Types of CV-joints and CV-Joint Wear
To satisfy the needs of different applications, CV-joints come in a variety of styles. The different types of joints can be referred to by position (inboard or outboard), by function (fixed or plunging), or by design (ball type or tripod).
Inboard and Outboard Joints
In FWD drivelines, two CV-joints are used on each half-shaft. The joint nearer the transaxle is the inner or inboard joint, and the one nearer the wheel is the outer or outboard joint. In a RWD vehicle with independent suspension (IRS), the joint nearer the differential can also be referred to as the inboard joint. The one closer to the wheel is the outboard joint.
There are two basic types of outboard CV-joints, the Rzeppa fixed CV-joint and the fixed tripod joint. Three basic types of inboard CV-joints are used: double-offset CV-joint (DOJ), plunging tripod CV-joint, and the cross-groove plunge joint. The applications of these vary with car make and model"
This is the type we have
