IDENTIFY THIS TURBO, PLEASE!
ILOVESILVIA(S13)
Car: 93 Ca18det Hatch, 03 Subaru WRX Wagon (daily), Subaru Legacy Limited GT (daily)
A couple of days ago I traded some extra parts I had for what the guy said was a stock CA T25 turbo because mine went caput. Well I just got a turbo in the mail yesterday that I thought was a stock CA T25, that is until I saw it. I knew in the back of my mind something wasnt quite right because it looked bigger and was significantly heavier. Anyway, I went to my friends garage today and took off the blown turbo, and thats when i realized that the turbo I recieved in the mail was not the right one.I know it is a nissan turbo, because it says on the turbo. But thats about all i know. Here are some pics of both the turbos together. If someone could please identify this for me that would be great.
ILOVESILVIA(S13)
Here
missionsix43
Car: 1989 240sx hatch ca18det
invisible pictures.. nice.
we are gonna need some of those to identify it.
ILOVESILVIA(S13)
missionsix43
is the exhaust manifold flange larger than the t25 one? measure the distance between the studs
might be a t3 from rb25..
ILOVESILVIA(S13)
I just measured them. Yes they are bigger.
ILOVESILVIA(S13)
what do you guys suggest i do now? It looks like it wont fit to the exaust manifold judging by the differnces in bolt hole distances?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
It looks like a Z31 turbo.
float_6969
It's a T3 from a Z31...
dvd
want to send me the nipple for the wastegate on the ca one if you're not going to use it?
ILOVESILVIA(S13)
Now, what the heck am i going to do with this Z31 turbo!! I guess i'll send it back to the guy when i get a hold of him.
davidricardo86
Car: 1992 Nissan 240SX SE
ILOVESILVIA(S13) wrote:Now, what the heck am i going to do with this Z31 turbo!! I guess i'll send it back to the guy when i get a hold of him.
You could make or buy a manifold for that type of turbo.
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
****, i'll swap you a standard t25 for that !! lol
float_6969
Yea, you got a deal there buddy! That turbo is good for about 275rwp IIRC...
nocwage
What are the specs on the Z31 T3?
nocwage
It looks like that is ACTUALLY the T25 off the Z31..
I found this image on the http://www.redz31.com/turbofaq/turbo.faq.htm
They say the one on the LEFT is the T25 from an 88-89 and it looks IDENTICAL to the one you posted.(The one on the right is the T3)
Bwana
Car: Denali
Somehow that just doesn't look like a t3 to me... It looks alot like a t2, but the bolt pattern difference puzzles me.
dash
Car: s13 ca18
z31 t3 has 7 bolts on the downpipe elbow.
float_6969
Wow, I just learned something new. I didn't know the Z31 ever had a T25 on it. WTF was Nissan thinking? A T25 on a 3L V6?
ILOVESILVIA(S13)
Well, i guess im stuck with this mystery turbo. Oh well, I got it for free basically. I guess i'll just keep it in a box until i find someone that might want to buy it.
On a side note, i was thinking about getting a T28 BB turbo after Christmas, do you guys suggest any mods i might have to do before doing this, or is it a simple bolt on affair. Im sure it has been covered before multiple times and i'll try searching but wanted to ask anyway while i have this post going.
c-rad
ILOVESILVIA(S13) wrote:Well, i guess im stuck with this mystery turbo. Oh well, I got it for free basically. I guess i'll just keep it in a box until i find someone that might want to buy it.
Depending on what turbo you are coming from, intake pipe needs to be modified, hotpipe that goes from the turbo to the intercooler needs to be modified. Oil return line has to be redone (on mine at least). Housing needs to be clocked if you are using a stock manifold.
ILOVESILVIA(S13)
I was thinking about this set up i saw. Would this take care of most of the problems you talked about if i buy all the accesories that are listed?
http://phase2motorsports.store....html
c-rad
ILOVESILVIA(S13) wrote:I was thinking about this set up i saw. Would this take care of most of the problems you talked about if i buy all the accesories that are listed?
Yeah, most of that stuff is good. I wouldn't pay $25 for that return hose though. You can get it just as easily from an auto parts store for about $2-3. Also, you still have to modify the hotpipe. You can use the turbo outlet piece from your existing turbo.
prsfan
Car: 1991 240sx
...this is kinda off subject, but, Have you ever been over to JK Motorsports in Greenville? Jonathan and the guys might know how to make this thing work for you. Maybe not?
http://www.jkmsports.com
J
ILOVESILVIA(S13)
Im really more into doing things myself then rather paying someone. But yea, i have been there and the Owner and his son are pretty nice guys, just dont like some of the guys that hang around there so i mainly just keep to myself.
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
float_6969 wrote:Wow, I just learned something new. I didn't know the Z31 ever had a T25 on it. WTF was Nissan thinking? A T25 on a 3L V6?
Raise the compression. Lower the boost. Faster spool. An attempt at better/smoother overall performance than the previous years stock.
The turbo does appear to be a T25, but it is not from a Z31.
float_6969
This is totally not CA engine forum related, but I don't care.
So you're saying that the VG30E(T) had lower compression and a bigger turbo in the older Z31's and then higher compression and a smaller turbo in the later years to improve throttle response?
c-rad
float_6969 wrote:This is totally not CA engine forum related, but I don't care.
Exactly what Mitsubishi did with the DSM... 1st gens had 7.8:1 compression and a 14b turbo (~260-280whp capable) and then the 2nd gens had 8.5:1 compression and a T25 turbo (220whp on a good day).
float_6969
Well if you want to improve throttle response, it works! Bad for midrange to peak HP, but you have to do what sells cars, and if people complain about turbo lag you've gotta fix it.
AZ-ZBum
84-87 Z31 Turbo: VG30ET, CR 7.8:1, T3, 6.7psi, 200hp @ 5200, 227ft-lbs @ 360088-89 Z31 Turbo: VG30ET, CR 8.3:1, T25, 4.5psi, 205hp @ 5200, 227ft-lbs @ 3600
