Identify this sound. **video included**
esqueue
My sr20det swapped 240 makes an odd tapping noise. YouTube - Sr20det redtop odd noise It is at it's loudest when the engine is cold, in 3rd+ gear between 2800-4000 rpm and with light acceleration. It isn't very loud at WOT. It seems that the sound is also louder in person than is the video.
This wasn't much of an issue until the cams were correctly timed. They were both off 1 tooth.
thanks
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
sounds like the chain hitting the top guides. take them off and see if it goes away.
esqueue
Wow, the third person. I will try this. Thanks.
3 or 3 is quite convincing.
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
nifares240 wrote:sounds like the chain hitting the top guides. take them off and see if it goes away.
Make it 4.
LovesBigTurbos
Car: VW Gti T3/T4 Turbo, 03 350z sold
if that don't work check valves
makeuw3t
that does sound like the chain guides, but if it is, thats not your underlying problem. the chain is hitting the guides because the chain is not being tensioned by the chain tensioner. you should look into fixing the tensioner or whatever use to keep the chain from hitting the guides.
good luck!
themadscientist
my FJ made the same sound when the upper chain tensioner s*** the bed. It was a deeper manlier sound though befitting a proper double row chain.
