identify this part
thes14project
Car: Thinking my friend and I have mechanical skills
In my s14, it is the canister right up against my radiator. does it have to be pluged in?
Also, where can I get a s14 temp sending unit for my s13 sr-> s14
thes14project
also, could anyone tell me how my Greddy type S BOV needs to be setup/adjusted?
gabossie
Car: Your mom
Charcoal cannister? If it's a little cannister connected to a few vacume lines, it's your charcoal cannister. Emmissions equiptment.
thes14project
I know it has a plug, but I'm not sure about vacume lines It reminds me of an Air seperator tank (AST)
extheflow
if it's bolted to the radiator support.and held on with 2 little studs then yeah thats the charcoal canister.the plug on there is so the ECU knows when it's jacked up.and can throw you a useless code.instructions for the type S are right on top.tighten it until it doesn't leak at full boost then a couple turns more.use the big nipple on the lower part.the small one can be left open.
s13sr20chris
is it all metal with two metal lines coming out? it may be your a/c reciever/drier.
thes14project
Thanks guys. For the type S how do I make sure it's not leaking at full boost? have someone rev the engine and adjust it?
