Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Sep 16, 2003 3:41 am
Just as a side note I finally finished rebuilding my front and rear calipers, new slide pins and seals [$60]. They were primo inside just a little 200 grit sand paper.Finally spent an hour grinding on my LF hub [255k] to get the runout down to where the rotor outer edge was less than 0.0016" [spec 0.0028"] it had gotten to 0.004".
Now if I can just figure a way to stop the warping every 7,000 miles [even with powerstops]..........gotta be the heat and metal masters.........everything is brand new.
