First
Hi i am new to Nissan Trucks (less than 6 months) and am almost sorry i got it even tho i like its looks and the carrying ability
What have i got?
ok that is one of the problems i am having
here is the info i can find on it so far
this is causing troubles and is why i am starting to not love it as muchAussie 1987 Nissan Navara (3/1987 japan made) 2WD
right hand drive
chassis # NGD21-001331
Model # NGD21FM
2.4L Z24 (S) 2389cc
points(hall effect replacement installed)
carby
pump in gas tank
Base Standard Cab Pickup 2-Door
Long wheel base
Diff / Trans Axle FS5W71C CA39
5 speed manual
things that have failed in the time i have owned it
head gasket (i am guessing the guy i bought it off used chemiweld to hide it) (fixed $892+ 6 hours of my time)
radiator (as above) (fixed $282+ 2 hours of my time)
speedo cable (dash end plastic bit came off internal cable) (carnt find part numbers)
speedo needle snapped off (replaced with superglue and painted toothpick)
fuel gauge sender unit in tank (sparky has checked the wiring and dash cluster and said all ok) (carnt find part numbers)
i am only getting 5.6Km to the Lt of gas (ouch)(my last car was 12.1Km to Lt )(fuel here is around $1.65/Lt)
i carnt seen to find this exact model anywhere
the closest to my truck i can find it the
1987 Nissan D21 E Cab Pickup 2-Door 2.4L 2389CC l4 GAS SOHC Naturally Aspirated
(my ute)1987 Nissan Navara D21 Base Standard Cab Pickup 2-Door 2.4L 2389CC GAS SOHC Naturally Aspirated
and have been told that the fuel tank is different in the E Cab fuel injection electronic ignition model to the one i have and wont fit
fuel sender units i am looking at but have been told there not for my model but the E Cab
BOSCH 67882
Airtex E8268S
Spectra Premium SP4017M
speedo cable i can find a 72" one or a 82" one but my one seems to be 67" but that is trying to measure it in place
72" 82"
there are a few other things i need to do , fix , replace but i'll get to them in due time the ones above are the critical ones i need to do now
i have already had to import a
set of tail light assembly
hall effect points eliminators
any help would be good thanks
