node wrote:The distributor is set to like 10BTDC and the cams are set with just a little less overlap.
Does the computer set the timing back to TDC for start, then advace after the car is running? Are you thinking the timing is too far advanced or somthing? I have tried the trick where you disconnect the TPS and the car still does the same thing.
Uh, why is distributor set to 10BTDC? And why are the cams set with a little less overlap? How much "less overlap" are you talking about? You can only jump a "notches" on the timing chain, if you know what I mean. You need to line up the cams and timing chain perfectly. Also try setting distributor timing to 20BTDC for starts.
Also, make sure your engine isn't getting extra unmetered air from somewhere, which could come from the egr system, idle air valve, or the valve cover breather hose.
