To level with you, you want to do a half assed job and are wondering how to go about doing it.oz240red wrote:Hey guys, Im about to start my KA-T project and though I'd tackle down the part I feel less comfortable with.
I want to tap the oil pan and wanted to know what you guys with KA-T had done regarding this.
I already took out the engine a few months ago to fix a bad oil pan gasket and front and rear main seals leaking. (I wish I had decided to go KA-T back then). So I don't want to take it out again.
I know there are some very creative people here, so I wanted to pick your brains on what you had done to make your oil drains for your turbos and what materials you used to create a seal.
I use the ACT Xtreme Street clutch, perfect for daily driving, rated for around 333ft/LBS but I have heard that Act under-rates there clutches and that it should be good for 400ft/LBS, guess will see once a bump up the boost.oz240red wrote:I guess another reason for taking the engine out again is to change the clutch and rear main seal. What clutch would you guys recommend for 7-10psi on a t3/t4? (it's my daily driver so I don't want anything too drastic)
I got another pan and welded on an AN fitting as high on the pan as possible between the AC compressor and motor mount area (when viewed with pan on motor).oz240red wrote:Hey guys, Im about to start my KA-T project and though I'd tackle down the part I feel less comfortable with.
thanks
LIESspank044 wrote:I drilled and tapped the block with a 3/4" pipe tap and used -10 an fittings.
Jealous Mod!WDRacing wrote:
LIES
S13FX wrote:
Just unbolt the damn engine mounts and the transmission mount thing on the bottom, and either jack the engine up with a jack where it meets with the transmission or use a engine lift to raise it a bit.
Un bolt the oil pan and take it out if you do it just like that it will clear the cross member no problem. QUOTE]
S13FX, when you did this you also removed the driveshaft?
Also, did you have to disconnect any lines or any part of the harness when lifting the engine to get enough clearance?
LOLspank044 wrote:
Jealous Mod!
You must have done this with the block off the car right?
Kinda surprised you havnt had any issues your oil lines and fittings are really small.spank044 wrote:
Jealous Mod!
Never had a problem with flow issues either.
Sir, this is very valuable infoS13FX wrote:Nope drive shaft stayed connected, I didn't disconnect any wiring. Like I said you just need to lift it up a couple inches.
how ever I just remembered you have to take apart your shifter cause when your going to be lifting the shifter will try to go up too.
But all you have to do is lift enough for the transmission to touch the top of the transmission tunnel.
My felpro gasket bull**** has been holding up fine this past year w/ plenty of hard driving...S13FX wrote:Oh and a friendly tip don't use no gasket felpro bull**** just normal high temp gasket maker.
that's awesome man!spank044 wrote:Oz, it was done when I was rebuilding the engine, it now handles 18psi daily and 27 at the track.
WDRacing wrote:Keep up the good work man...it'll pay off in the end.
WD
hmm, yeah, that seems like the best way to go. I just have to make them wide enough to make the holes offset, because the radiator support beams where the horns go bolted on don't align with the I/C holes.spank044 wrote:It appears that if you got a deep piece of 90 degree angle and bolted it on the rad support and the other to the Ic then it would be very simple.
