Ideal sub box...
Post all your Nissan electronics, car audio and stereo questions here!
mkory
Car: Mazdaspeed Miata
I had a sub given to me by my stepdad. Me and a friend of mine installed it yesterday. It's a Rockford Punch 10 inch in a truck box. It sounds damn good for only being a 10, let alone in a truck box. What's the ideal box for this to get the most from it?
PoorManQ45
I take it that you don't have the manual? It'd usually tell you what the optimum box is. Or at least it would give you information as to what size you have to build it.
Usually ported/vented will give you the louded bass. Sealed will give you the "tightest" bass.
mkory
Well... If I can manage to get another friend's 15 for the time being (while he is car-less) I'll probably go with a ported box for the 10, or a sealed box for the 15. No, I do not have the manual for the sub, like I said it was just given to me by my step dad, who got it given to him too.
Ideal size?
PoorManQ45
Try a program called WINISD. It will usually give you a very close estimate for different type box sizes.
I'll play with it for a bit, that sounds sick, and post what I come up with.
92nicoman
Car: 1988 Nissan 200sx
well maybe u should let your friend build the box for u I know he knows how he is all ways working with speakers
PoorManQ45
Would you happen to be his friend
mkory
Thanks Chad, but I'll build my own box, I just gotta get the right dimentions from PMQ first.
mkory
Actually, I want one of Zach's 15's.
92nicoman
i got all the stuff to make it and i can the dimminson off daniel or glen tomorrow if u want me to.
mkory
Only if you're making it for free.
92nicoman
i am going to make the box for zach's 15's did u know that or not
92nicoman
sure y not i will charge zach though dont tell him
PoorManQ45
Is the 10in Rockford 4ohm or 8ohm nominal?
I'll assume 4ohm unless told otherwise
mkory
No, I didn't know you were building Zach's box for him. I don't mind building my own, I actually like doing that kind of stuff. Where are Zach's 2 15's going?
mkory
PMQ, I dont know what the ohms on my sub is.
PoorManQ45
I don't know if you'll be able to see this, but here's a picture of what the frequency response of your sub in a 3.791ft^3 vented box tuned to 33.02Hz will look like.
92nicoman
Summers Car but i am going to try to talk him in to puting them in to mine if i get a new car hey keep an Eye out for a 240 for sale for cheap k well i am getting off here talk to ya later
PoorManQ45
Unfortunately the sub you have is going to require a large enclosure to get a reasonably low frequency response.
If you don't have the space, I would recommend an MTX 12 in a sealed enclosure or something else that costs too much.
I suggest a Cerwin Vega HED 12in
mkory
I don't really plan on spending any money on this unless it's materials to build the box. I never had any intentions on putting any subs in my car, it came with a 640 watt amp to push highs and mids, and a 1000 watt amp just for subs. I parted out the 1000 watt amp within a week or so of owning my car because I had no intentions on putting in subs (since the previous owner took his out before he sold it). Now that I have a 10 incher for free, I do like the way it sounds, and just want a little more out of it.
What is 3.791 cubic feet in terms of height/width/depth. I'm really bad at calculating things in reverse.
PoorManQ45
Well, think of one cubic foot as 1foot by 1ft by 1 foot. Now you box will be nearly 4 ft by 4ft by 4ft. That's pretty damn big man. You won't have a trunk left, unless you have an SUV.
Now, you could BUY another sub that is exactly the same, model company, and build an isobarik enclosure totaling 1/2 3.791ft.
I don't think it's worth it to loose your entire trunk
PoorManQ45
Seriously though, check out Cerwin Vega 12in HED sub. It's $60 for one. WHich is dirt cheap.
mkory
I'll check that sub out. Meanwhile, since a 4x4x4 foot box is out, what size box will suffice for the time being?
PoorManQ45
YOu can get away with a 2ft^3 box tuned to 34hz
Florida240sx
Who needs a trunk?
PoorManQ45
Sorry, I totally had a major brain fart when I was explaining cubic feet dimensions.
A 6ft^3 box would have these dimensions: 3x2x1.
Florida240sx
PoorManQ45 wrote:Sorry, I totally had a major brain fart when I was explaining cubic feet dimensions.
Mine was 37.5''x24''x10'' Gave me 3.985 cubic ft used 3/4MDF board
Rex
Car: None
Huge boxes are great, but rather impractical. As much as getting a sub to recreate a 20hz tone in a car is cool and all, it's not really practical or necessary.
I generally suggest building the largest "practical" box you can, then find the best sub for that box, or subs (clamshell isobaric) and don't get stuck trying to fit a sub into a box .
PoorManQ45
Yeah, that's what I'm going for with the enclosure I'm building. The farther I get on it, the larger it seems.
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
I agree with Rex, it's not practical in most home systems, why would a car with even less space be a better location? Plus the weight that an enclosure that size adds is huge. The current model Rockford P210S4 10" subs require at least .75 cuFT or more. That would be internal diminsions of 9X12X12, with 3/4" MDF the external box size would be 13.5X13.5X10.5 inches. Forget about trying to tune the port of a car sub enclosure to 35 hz, most music doesn't have many audibles at that low of a frequency, and with road noise you would be able to identify the note anyway, unless that is the only speaker in the car.
PoorManQ45
Silvia2b wrote:I agree with Rex, it's not practical in most home systems, why would a car with even less space be a better location? Plus the weight that an enclosure that size adds is huge.
Nope, that's what Fiberglass and other fibers are for. 1/3 the wweight of MDF with the same strength
