turtl631 »
https://forums.nicoclub.com/turtl631-u15171.html
Thu Dec 02, 2004 7:12 pm
My goals for my s14 are to have nice neutral to slightly rear-biased handling, for use with street driving, mountain roads, autocross, and perhaps road courses later on. I want to get rid of most body roll without making the ride ridiculously harsh, and I want good balance and grip. Most of the talk on this forum focuses on wheels, tires, and coilovers, with little about sway bars, bushings, and alignment specs. So far, I'm planning to get 17x8 +28 with 225/45/17 Kumho MX all around, either Megan Racing or KTS coilovers, SPL tension rods, and probably Cusco/SPL RUCAs. I already have SPL aluminum subframe bushigns to firm up the rear, adn the stock SE sways. I think I will go with a relatively mild drop to retain travel, especially in the front, and shoot for around 1.5-2.5 degrees camber front, 1-1.5 degrees rear, 0 toe all around. Is this a good setup? Will I need other adjustable arms (traction, toe) to achieve this with a moderate drop? Are there any control arm bushings that I should replace with poly or nismo bushings for better response? I know the subframe and tension rod bushigns are really squishy..how are the others? I'm also curious about sway bars. I was thinking that the adjustable whitelines would be a good way to fine tune balance and also keep body roll down with softer damper settings, which should help the dampers absorb bumps better, correct? Next, what can caster do for handling? I remember reading somewhere that altering caster in one direction reduces toe changes (bumpsteer?) under compression, which seems like a good thing. Yay or nay? Wow, this post got out of hand, but I haven't found much on these topics even with searching. Any pointers/tips appreciated
