lovespeed »
https://forums.nicoclub.com/lovespeed-u54066.html
Wed Dec 10, 2008 6:55 am
The first thing you need is a service book do you have a Haynes manual or something because it is a must to have when working on your car. Second do you have a multi meter (volt meter) if so you need to check the voltage at a couple different sensors by inserting a back probe into the back of the connector while it is still plugged in (paper clips work good as back props) but without the book to tell you what voltage, or ohms you should have it won’t do you much good. Off the top of my head you should have like .5 volts at idle and 4.5 volts at WOT. But it is probably your idle air control valve or something like that.
