That woul be really sick and clean looking, Thats giveing me ideas.White Comet wrote: so im thinking of an led brake light mounted inside the glass
heck yea. i am getting ACT cutch, XACT flywheel, GT2871r .64 turbo, MR turbo extension, new exhuast mnaifold studs, and skinny o2 adapter, plus turbo accessories.Slideways^Jordan wrote:so Idaho are you getting anthing for your car on christmass.
why wouldnt it pass inspection.? you still have your other brke lights. it will look nice with that stuff shaved.White Comet wrote:sounds good, i shaved my rear squirter and antennae. what are u doing for the third brake light though? i am thinking about shaving mine btu in PA it wouldnt pass inspection and i could get pulled over fro it, so im thinking of an led brake light mounted inside the glass
YEA around here the cops dont care, since most of the cars running around are mising taillights and head lights and crap lol.White Comet wrote:if ur car came factory equipped w/ 3 brake lights u gotta have all of them. even if i pass inspection i'd probably get pulled over and hassled for it. its not worth it wne i can just shave it and do an led 3rd brake light inside the glass
well i havea triple radio din gague cluster, and i hada double piller mount to.i only have four gauges coming right now. i think i will put my boost gague, and then when i get my A/F r gague it will be i nthe piller too. the otehr gauges will be oil pressure, oil temp, and exhaust temp.duffman1278 wrote:Awsome, where do you plan to mount the gauges??? A/C vent or on the pillar?
Good xmas gifts btw, makes me jealous
the brake light inside the glass would be kidna cool. but my tint will be to dark to to realy be able to see it most likely.
how dark of a tint are u doing? im gonna do an led 3rd brake light and if that cant shine through ur tint then it must be black spray paintidahotuner wrote:
why would you get a water temp gauge when you have one stock.White Comet wrote:i dont have all the gauges yet but im going boost and water temp on the a pillar and then oil pressure, exhaust temp and a/f ratio in teh vent area in that order
i ma jsut going to find some wire the same thickness and solder it in to lengthen mine.duffman1278 wrote:Do you guys know what wire I can use to extend my O2 sensor plug so I can plug it into my harness?, I don't have a spare O2 sensor to splice it. Could I just use another kind of wire?
All that dinky thing does is read fine, warming up, fvcked...idahotuner wrote:
yeah but the factory gauge is so inaccurate its useless. it wont tell u ur overheating til its too late. theres three readings on it; cold, operating temp, and long goneidahotuner wrote:well it doent show acutualy operating temp. but it will show you when it is startign to run hot. s o i dicided to cover areas that wernt covered al lready. as far as gauges go.
I agree for a car not seeing track abuse.White Comet wrote:i would have gotten water temp instead of oil temp. if u have water temp and exhaust temp, ur pretty much going to be covered for temp monitoring
