i wired them up wrong. lol when the brights are on. both the dims and brights are on instead of the brights and driving lights. so then when i flip to dims lol its jsut the driving lightsKalypso123 wrote:whats up with the headlights
first off. i am going to say it could be coming from your turbo oil feed line possible. but what do you mean the spark plugs and cas are not getting fire.Kalypso123 wrote:ben i need your advice...
problem 1
I just came back from the shop andthere is oil leaking down the driver side of the engine block,it was dripping before but when it tries to crank - it gushes. their is a puddle on the floor.
its coming from between the AC compressor and the exhaust manifold. is it the head gasket?
if so, I have another - but I am trying to narrow down the possible sources of the leak.
problem 2
spark plugs and the CAS are not getting fire. I am going to bring an alternate fuse box to try my luck. but it seems like there is a short in the harness or maybe a bad fuse.
I run 16lbs on my s15 turbo, 550c injectors, z32 maf, fmic, rom tune etc, it runs perfect I have a wideband hooked up as well, its spot on, I dont know, my friend drovethe car and it sounded pretty beast... I was hoping SR`s would sound deeper like dsm`s, but I guess not, cant win em all.idahotuner wrote:i think the way your exhaust sounds isa direct result of how your motor is running. i have been running into alot of moddified cars that sound like 2 strokes almost. and i think alot of it has to do with tunning. if you havea dead on tune then your exhaust is going to sound alot better.
and i dont mean to brag but i think out of all the cars i have ran into lately my exhuast sounds the best. maybe i ma lucky
DOnt rattle can your car, your dad will probably tell you, but rattle can is laquer paint and will be the week link in your final paint job. If you want a temp deal, go spend 50 bucks on catalized base coat.idahotuner wrote:well looks like i will be rattle canning the car for a temporary deal.
pull the plugs out are they all oily. if so then it would be your head gasket. causeing the problems
haha yeah. i should, atleast so it is hitting the ground.ILoveMyRHS13 wrote:You need to add extra zipties to the Honda emblem so you drag the son of a betch!
I am taking it to a wiring specialist. no worries.idahotuner wrote:i would say that ss lines would be a good investment. make sure you use form a gasket on the threads. or thread lock for the oil feed one.
my electrical abilities are not very goood either. because even i hav e to track dow na wiring problem right now and it sucks.
