Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Oct 11, 2010 11:40 am
If you're buying brand new rears from Nissan, they are definitely not cheaper. The fronts are ~$130 a piece, plus you need an S14 front knuckle and ball joint. Then you're looking at ~$260 per rear.
Granted, it gets infinitely cheaper if you use a salvage yard, but if you're trying to get brandy newy stuff, Ichiba is the way to go.
I will say that if the bearings themselves are OE spec, you can probably get lucky and try to swap in some OE bearings.
