We'll be getting to the Hy-Line ferry (or Steamboat Ferry depending on our actual time of arrival) for the last ferry out on Thursday. This is my first time out there and I'm really looking forward to sitting on my butt for a few days.
If you look down
this page, you'll see a picture of the CA18DET RWD throttle body. It has a plug dangling off of the TPS. I remember the EXA guys saying to use wires from un-used sensors/solenoids to hook it up correctly. Since the EGR and AC throttle solenoids won't be used I'll probably just use those wires. Got a new question to add to the list:
Questions
1. What is the purpose of the plug that's dangling off of the throttle body and how does it get hooked up?
2. Where can i get the little lock down U shaped wires for the harness plugs?
3. Since I have a WBO2 that has a narrowband output, can I just hook that up to the ECU and skip the engine harness side for the O2 sensor?
4. The CA16DE has four solenoids (AIV, Power Valve, EGR, and FPR). In a pin out conversion diagram it showed the CA18DET having the Power Valve and FPR solenoids hooked up. Whereas on a CA18DET vacuum diagram, it only shows the Power Valve being hooked up. Which one is true?
