qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Thu Sep 27, 2007 5:14 am
It's possible to "tweak" the system by modifying sensors. The trouble with the newer vehicle is that the computers are pretty smart. It doesn't only take into account one sensor to adjust the parameters like fuel ratios, timing etc. If you try and change one sensor by very much it will just ignore that sensor and revert to another as it will see there is a discrepancy.
There are many tricks and simple mods and circuits you can do and I've tried a few. My experiments have been attempts to increase MPG primarily. The IAT mod alone won't really do much, if anything and on a newer vehicle like your '02 model, you are very likely to get a check engine light when the ECU figures out you are messing with things.
There are many "snake oil" salesmen out there, particularly on e-bay, peddling resistors concealed in heatshrink and other enclosures, for huge profits. Don't buy it!
