IAT's on KAT's
ultimatuc
Car: fast cars, big trucks, sluts
Do you guys run your iat's in your plumbing? or just let the dangle?
TrunkMonkey
Car: 2000 Lincoln Navigator
i may be having a brain fart or something, but what is an IAT?
-demetrius
candela
Its nice to have one on teh hotpipe and before the TB for comparison sake...however the TB one is prolly most important as thats pretty close to what the motor will be ingesting.
I beleive by IAT you mean intake air temp sensor...
ultimatuc
yup. Inatake Air Temp
DriFt3r
Car: Racing and Drifting
i just tuck mine away..........
TrunkMonkey
ultimatuc wrote:yup. Inatake Air Temp
doh! :doh
-demetrius
red240ne
Car: mmm...donuts
I just shove it in the air filter. :D
Nathan
I forget, is this only an S14 or Cali thing? I dont remember seeing such anywhere in my intake tract on my S13...
WDRacing
I plumb mine into the itake, to easy to drill a hole and seal it up.
WD
ultimatuc
It doesnt make sense to me to run the IAT before the turbo and intercooler, because the air temp will be changed dramatically. However, from the factory, the IAT is installed before the MAF. so I dont know what efects there will be having it after the maf.
any more input is appreciated. thanks
ultimatuc
The IAT is a thermistor, which changes its resistance, w/ change of temperature. so I'm starting to ponder, running a fixed resistor in place of it for tuning reasons. I need to know, how warmer or cooler air affects injector pulses. ( I'll ask my instructor mon. ) ( UTI )
any input on this?
WDRacing
I suppose plumbing itafter the IC would give the ECU a better temp to work with. I hadn't thought to much on this until now. I'll probably be moving mine as well.
Brian
red240ne
Car: mmm...donuts
No, you want the IAT to get cooler charge air readings.
If you have any GM, then you should know all about the IAT "free mod". On most modern GM vehicles, the IAT is placed in the intake manifold, but for a "free mod", people run them where cooler air is drawn in, like the intake tract. This is on a system that relies on the MAP sensor though.I don't know for sure how it responds in a MAF system.
curt
ADAMHU
mine is just dangling
huguetpj
Car: 93 KAT Coupe
Nathan wrote:I forget, is this only an S14 or Cali thing? I dont remember seeing such anywhere in my intake tract on my S13...
Nope we ain't got it. I'm sure all S14s have it (or at least ODBIIs), not sure if the Cali S13s do.
red240ne
Car: mmm...donuts
huguetpj wrote:Nope we ain't got it. I'm sure all S14s have it (or at least ODBIIs), not sure if the Cali S13s do.
hmm...I wonder if my 95 is OBD-II?? I've never really pondered the thought..maybe I should check it out.
ultimatuc
^ your 95 is obd2.
Structure240sx
my 95 is obd. it was produced techniqually in 94 tho. i have my right before the maf maybe i will move mine also
red240ne
Car: mmm...donuts
ultimatuc wrote:^ your 95 is obd2.
why do you say that?
curt
WDRacing
Cause 95% of all 95's are OBDII...
DriFt3r
how can you tell if you have obd11 or just obd1
