IAP's Oil Return Line (Any Leaks)
jmwenick
Car: 1991 240sx Base Model
Hey guys, I'm thinking of buying IAP's Oil line kit, but was wondering ifanyone has had any leaks. I know that it is not welded on, so thats why I ask. Let me know.
Why would anyone want a welded-on oil return line?
Makes it kinda hard to disassemble for maintenance or cleaning (or engine repair0.
Mine works great, no leaks.
WDRacing
Yeah, when your car is actually running....LOL.
I'm driving to Tucson right now to KICK your a$$.
Love you bro.
fiznat
Car: Grown up :(
A welded return line is usually just a welded in bung, and then the line threads into that. You can always just unscrew it for easy disassembly- while at the same time the welded connection goes a long way to stop leaks.
The jury is still out on how well the "weldless" return bung works. I have seen some have trouble, and others none at all. The difference seems to be a mixture between luck and how well it is installed.
WDRacing
I'll get out the Suave for ya!!!!!!!!!!!!
adoboboy
Car: s14
I have the oil feed/return kit from IAP...I bought it un-used off from someone, but not sure how it goes together? no instructions came with it...=TI emailed IAP but no response...
You can reach IAP at 513-325-8421
Florida240sx
I had a small leak with mine but it was my fault.Put soem new teflon tape on and it's been good eversince.Right up to the point I screwed up with my injectors and spun a bearing.
