IAP Manifold
300max
Car: 1995 240sx ka-t 1997 Maxima SE
This is for anyone running the IAP manifold. Is there enough room between the downpipe and wastegate outlet to run a separate exhaust system for the wastegate. I dont' want to exhaust the wastegate near the passenger compartment and I remember that someone on this site was having problems connecting the dump tube to the downpipe. Thanks in advance.
Nathan
You could probably run one alongside your normal exhaust system. I know the muffler shopped *****ed about making my wastegate dump, but they got it done...if mine had a 90 degree bend at the bottom it could have run along with my big exhaust as a seperate system. I just dumped it though...screw the fumes, I like em' :D
red240ne
Car: mmm...donuts
I have the IAP manifold. The dump can be run in a straight line to the downpipe. Why'd you make a 90 degree bend??
The only problem I had with my IAP downpipe/mani is that my brake booster was in the way of the downpipe. That was solved with a hammer though:D
curt
Nathan
Because I didn't want it put back into the downpipe ;)
