dj_hype wrote:wait, your tryin to boost 7 psi on stock injectors? do you have an fmu hooked up temporarily or something like that? thats kind of scary. personally, i wouldn't even start the car unless i had my 370s installed. well, i might start it but wouldn't rev it and def. wouldn't take it for a drive.
A while back, there was a discussion about this turbo kit on a local board I go to. I basically said I didn't like using stock injectors and fuel pump on their "Stage 1" kit. Next thing I know, someone from IAP was on the message board and said I was spreading mis-information. So, I asked to see dyno pulls with A/F ratios proving that the engine was not running lean with that setup, and never heard back from them. Fact is that at 7 psi, the factory injectors are going to be running close to 100% duty cycle, which is never a good idea. The kit seems fine other than that.
Best bet would be to either get bigger injectors or get a WG spring that limits boost to no more than 4 or 5 psi.
Modified by 2FourTee at 7:03 AM 2/7/2006
