DammitBobby wrote:Do not put silicon on the drain line that is a NO NO! Ask me how I know!
Because when you press it against the mating surface, the silicone squeezes out and chokes off the drain hole. BOOO!
DO NOT SILICONE THE DRAIN FLANGE ON! Not only will it clog up the line, but the severe vibration of the engine/turbo will work it loose, and you can destroy your motor from oil starvation. What the hell is IAP thinking?Anyway the bolts are easily gotten from ACE or any other hardware store. I recommend hex-cap for clearance issues, but that's just me.-Jeff
