dj_hype »
https://forums.nicoclub.com/dj-hype-u32660.html
Tue Oct 18, 2005 4:51 am
Ok, I was bored today and decided to read the instructions for installing the IAP Stage 1 kit. As I was reading, I came to this section:
Step 14: Align included oil return flange HORIZONTALLY on the oil pan so you can look down the driver’s side of your engine and see it between the motor mount and A/C compressor. Hold flange in place and drill oil pan with a 1/2” drill bit to allow oil to return to oil pan. Align oil return flange and gasket with hole drilled and drill 2 3/8” holes that align with flange into the oil pan going through the pre drilled holes on the oil return flange and gasket. Use included NutSerts, tool and ¼ x 20 bolts to attach to oil pan. DO NOT OVERTIGHTEN! Apply generous amount of included Permatex silicone sealant to outer edge of oil return flange to ensure a leak free fit. Allow at LEAST 8 hours for the sealant to cure before refilling engine oil.
Does this mean that you don't have to remove the oil pan? What about the shavings that fall into the oil pan from drilling? If I could get away without having to pull the oil pan that would be great.
