hysteria wrote:are all of your sensors hooked up? yes the distributor could be off a tooth. your timing chain could be lined up incorrectly. it could be a million things, but right off hand when you open the throttle and it wants to die sounds like the mafs is unplugged and your idle is not set right. have you checked the timing with a timing light? more info please.
Hey thanks for the reply, everything is hooked up properly, when i rev it sounds weak, very wired, it basically sounds like if you have an injector out(only one). It doesnt really sound like the maf, from my thing. Its really wired, because as like i said one of the four injectors keeps on going out. iam getting a timing light soon, hopefully by tomorrrow. thanks
