Skidmark »
https://forums.nicoclub.com/skidmark-u35273.html
Thu Dec 15, 2005 2:46 pm
I don't find this impossible to believe. If you look closely you will see the valve reliefs (something factory pistons do not have), which means either this piston is meant to be run with some gnarly cams, or it's high compression, maybe both. You're right about the fuel, though, I definitely wouldn't run those on pure pump gas, and I wouldn't go to the trouble of running alternate/mixed fuels on an N/A motor. But that doesn't mean no one else would. I could see them being real.
