IACV wiring
nismo24T
Car: b-ball, 240sx
I bought a new uncut SR redtop wiring harness...this harness has three wired on the connector that i'm assuming is for the iacv valve...but it doesnt mate with the IACV valve connector...this connector coming from the valve has like 6 to 8 wires...any thoughts?
S13FASTBACKSR
Car: '92 Fastback SR powered
pics? not your tps connector is it..did you find the one that mates with the IACV?
nismo24T
Car: b-ball, 240sx
I old harness that i took out looked like it was a 240sx harness which was converted to the SR...so that has the connector on it...well anyways...this is where im stuck at
The brown connector is coming from the harness.
nismo24T
Car: b-ball, 240sx
ok..i need a three wire tps
S13FASTBACKSR
when it comes to identifying plugs or little things like that my memory is not good enough but that grey one does look like the tps plug IIRC..is it the 6 wire?
nismo24T
Car: b-ball, 240sx
yup...six wire...can this be hacked to fit?
