jonnydclark »
https://forums.nicoclub.com/jonnydclark-u100474.html
Tue Nov 11, 2008 10:34 am
Hello,
I recently bought 2001 Maxima SE 5 speed. Replaced MAF (which it needed) but still had a bad idle problem. I replaced the IACV, tried the idle relearn, then gave up and took it to the dealership. At this point they said it is a wire harness issue and they want a blank check to just trace it down without knowing how long it will take. Should I let them?
Can I trace it down? I am a mechanical engineer with decent electrical knowledge. I looked at the ECM board and couldn't see any burnt traces. I understand that IACV can hurt the ECM or visa versa and if I have to have to replace the ECM I will have to reprogram the key chips. What would I look for if I was to trace it myself? Where could I find wireing diagrams?
Any help would be appreciated. Even just sending condolences. I need to get it fixed to pass inspection although it is quite driveable now.
Jon
