Exactly.Slumpert wrote:Seems if the iacv goes bad it creates a short/over current draw and blows out ecu most of the time as well.
Ecu is repairable or replaceable, just a fyi when you replace the valve and still no change
Either that, or replace your IACV as a precaution if your Pathy/QX4 is 10 years or older, and has over 150K miles on it.Towncivilian wrote:I wonder if there is a way to insert protection of some sort to safeguard the ECM should the IACV short out. Diodes? I don't know.
