IACV? useless?
GO240
Car: 1990/1/2/3/4/5/7 240sx lol
yesterday a friend of mine came up to my job with his new dual cam swap and he was running his motor with out an IACV so now i'm wondering if you need one or not he said the only problem is sometimes it goes up and down at idle anyone else not running yours?
thrasherx89
Car: 90 hatch (91 dohc, tein, z32, ss, injen, energy, b &m)
without an iacv? hmmm i think there is a mistake
if you have your iacv missing your car will have a massively huge vaccum leak and if you have it removed and pluged off your car will not idle at all
hense the name
Idle Air Control Valve
i would love to see pictures of his iacv missing and see his car running fine that is very puzzling and in either case, its not like you would save much weight by removing it so no point really
Mr.Fahrenheit
Car: 1969 Datsun 510
well actually im building my ka24de for a 510 swap. the guy i bought it from removed the iacv, egr, and the iacv regulator and blocked it off. unsure if this will hurt the performance of the vehicle or even run but he was running it in his 240 so i can only hope i wont have any issues in the 510........what you guys think??
240freak90
Car: 90 240sx KA24E
it wont hurt it one bit.. if you look it up in a manual all the iacv does is control idle when decelerating for more than ten seconds, on start up and some other few bs things like that. the air regulator just warms up the intake charge when its cold. im assuming it does this by the egr?? im not sure but yes it will run and if for some reason it wont idle then there is a throttle stop on the throttle body just adjust that for the desired idle.
Mr.Fahrenheit
sweet, thanks man!!
