rgk »
https://forums.nicoclub.com/rgk-u245656.html
Sat Sep 24, 2016 10:30 am
IACV/TPS took out the ECU. Replaced IACV, TPS, and had the ECU repaired.
Now getting an idle around 850-900 in park, and timing is 5-8 degrees.
Short term fuel trim is -10% per bank (rich condition?).
Long term fuel trim is 0% (needs drive cycles?).
Performed idle relearn several times with no success.
Checked for vacuum leaks, properly set TPS per FSM.
Does the computer have to OK all datasets (EVAP, emissions, etc.) via completed drive cycles before it will idle correctly or even perform idle relearn?
Cleaned out throttle body with IACV removed. Perhaps I dislodged some carbon and am now letting in too much air? There is still some carbon left on the sides that I could not clean. Perhaps clean this?
Any ideas? Thanks.
