iacv removal?
Darchangl
Car: 95 240sx Ka-t (in progress)
After searching the forums it seems everyone thinks it should be left on? why? Cant you just move your idle up on the TB to give the engine more air? I want to remove mine because I broke the connector on it when i was installing my engine, so i figured wth why not just take it off.
neverlift
being in tx I assume you could get away with it, seeing the temps are not that cold ,often.
some with custom manifolds dont run it....
egan
its fine, i removed and blocked mine. just harder to cold start/let her warm uo for a couple mins
