Shocker wrote:Your idle screw set properly? and also does it fluctuate up and down like it has a huge cam? Your TPS could be bad. How does it drive under load?
i dont know about the idle set screw, how do i adjust that?
no it does not fluctuate much, when i let off the gas it will got down to 1000rpm, then go up to 1200-1800 and then stays there till i rev it up again.
it drives fine under load, has good power all around no sputting or hickups.
craz4240 wrote:It's the unit held in by 4 bolts at the back of the intake plenum with a brown plug going to it.....take it off clean it with card cleaner,make a new gasket and snap her back on.,..if this doesn't help you no doubt have to set your idle switch.
idle switch? is that the same as the idle screw?
