Peabody »
https://forums.nicoclub.com/peabody-u10351.html
Tue Oct 24, 2006 12:01 am
Yeah I know it came off my car. People were saying to take the epoxy off the brass screw and remove & clean the screw. I thought they were talking about the sohc but now I know they were talking about the iacv on a 91. Can I use a 91 iacv on my sohc?
And yes vancouverbc I said your idle is fine when you are coasting? Your idle only goes up when car is stationary. That is probably the key to the puzzle. But that is a puzzle I cannot figure out. It is really not fine when coasting just lower. When I push in my clutch and coast it drops sometimes down to 400-500 RPM's and will stay that low and then when I come to a stop it starts to climb to it hits 1500 RPM. Also when I first start the car it will sit at 1500 RPM's and not go down. That is why I tried to clean the IACV.
Could I be stuck in high idle mode? I live in New Orleans and it is still in the 70's so I do not know if that could be possible. Can I check anything about that and also I took my TPS off to clean and never adjusted it with a volt meter. I need to search for a post on that. I did see one but it was hard to understand. I know how to use a volt meter, but I was not sure where I should check the voltage. On the harness, on the sensor, should the sensor be pluged in and checking through the wires or on the pins of the sensor. I know it should be 0.45-0.55 but not sure where toget that reading.
Sorry I changed the subject in my own post. I know people get pissed when this happens.
Will mess with it more in a few hours. I know I have a factory manual just need to find it. THANKS FOR THE HELP!
