toadx8u wrote:i pulled my whole assembly off and then fabbed up a plate out of some sheet metal to block off the hole
Im using my greddy plenum with sentra IACV disconnected.
Trying to get the car to cut fuel on decel is a MAJOR pain in the butt for me right now.
It will cut fuel on decel if i have the TB fully closed, and TPS at .44 volts.
IAC screw is backed almost all the way out but car wont idle by itself. If i set the TB open a little, it'll idle but then doesnt cut fuel on decel.
I do not have a neutral switch hooked up, and my IACV has never worked electronically. Any suggestions? Do i need that neutral switch in there for the IAC to work at all? This is a NEO btw.
Thanks guys!
John
