kirk wrote: FIXED!!!!!!!!!!!!!!!!
A big thanks to everyone who has posted back to me on this topic!!!!! I couldn't have done it without you guys!!!!!!!! YOU RULE!!
Got home. Let the car cool down a bit. Pulled plug off of AAC. Car idled the same. Hmmmmm.....So I went ahead and pulled the codes on the ECU:
12 - MAFI figured it would throw this because I had unplugged my MAF while it was running.
13 - Engine coolant temp sensorSame thing, pulled when the engine was running. (man that computer is GOOD!)
34 - Knock Sensor CircuitHmmm... come back to that later
45 - Injector leakWhat the heck?!?!!?! OH well.
So I reset the codes while I was in there. And it showed 55. YAY!
Here was my train of thought.1. Air regulator can be ruled out. Car idles high when cold, and idle goes down after warm.
2. FICD is good. When I activate A/C, idle goes up.
3. That leaves me with the ACC. Since I unplugged it and the car's behavior didn't change one bit.
Took IACV-AAC off of car. Tested solenoid again. Read 10.7 ohms. So solenoid is "good"Got to looking at the AICV unit itself and LOW AND BEHOLD THE SPRING WASN'T DOING IT'S JOB!!! The spring had gotten weak over time (I guess) and wasn't pushing the plunger against it's seat!!!! YAY!!! Now how do I fix it? I'm only going to buy a new one as a last resort!
If you ever notice on the same side as the idle adjust screw, there is what looks like an epoxied hole. Well, if you chisel away that epoxy (jb-weld) stuff, there is a Brass screw that holds in the spring and plunger. (see attached pic)
http://nissaninfiniticlub.net/...t=500
I thought about how to get another spring that was the same, but then I realized it would be a whole lot simpler to just shim the spring. So I cut one of my vacuum hose plugs (like a cross-section) and this fit PERFECTLY into the brass plug. As you can see in this next pick, the brass plug has a seat for the spring to rest in, and the donut shaped piece of rubber fit just perfect. I couldn't have planned it better myself.
Put it all back together. Now I have adjustment with the brass plug on how much seat pressure the spring will apply to the plunger. I thought that might come in handy in case the solenoid isn't that powerful.Anyway, put it back on, car ran just DANDY and now I can adjust the idle down to 600 (with tps unplugged). I actually had to idle it up a little, because I'm so used to it running so high!!!So my brother and I went out for a ride, and the car runs just PERFECT!!!! Idle goes right down when getting out of gear. Idles like a stone! Just completely fixed my problems!!!!
Sorry for the long post, I'm still so excited!!! Just had to share with you guys. Thanks again for the help!!!! I wish I could shake your hand and tell you how much I appreciate it!THANKS!
p.s. pulled the codes when I got back and still had the 34-knock sensor, but I'll save that for another topic and another day!
THIS FORUM RULES!
