IAC valve ????
bk240sx
Car: cars,hunting
does anyone know what iac valve i might have. auto zone says there is two different ones and the name will be stamped on mine but its not there. i have a 90 240sx auto. i never knew there was a difference. but let me know what you think.
Mayhem_J30
Car: Ummm...My Car
can't you just give them your VIN#. they should be able to look it up
bk240sx
Car: cars,hunting
they said i have to read it on the part but i havent seen anything on it. im gonna look again tomarrow but only thing i find is nissan written on it.
Nismo_Freak
Car: 89 Nissan 240SX
ahh... gotta love all the valves motors have... Idle Air Control Valve... who needs it?
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
I've got a question related to this....
I'm installing my standalone...or trying. There are four IAC wires, but only 2 on the Nissan IAC. However, there is the IAC Valve and an IAC Valve regulator. Together there are 4 wires....the wiring diagram reads A "Hi", A "Lo, B "Hi", B "Lo"...any ideas? You think I should try to hook up the B Hi and Lo to the IAC Valve Regulator? Not a big deal since I'm going to use bullet connectors, and I know the IAC is not necessary for the engine to run, but it would be nice to be able to control the idle.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
bk240sx wrote:does anyone know what iac valve i might have. auto zone says there is two different ones and the name will be stamped on mine but its not there. i have a 90 240sx auto. i never knew there was a difference. but let me know what you think.
Have them look up an 89 240SX and see what it uses. Usually, auto parts places list part numbers for parts on the years before and after the year you ask for, when there is a change in parts.
For instance, if you ask for a '90 part, they will probably have part numbers for KA24E and KA24DE listed. But if you ask for a part for an '89, they will probably have the VG20E and KA24E listed. So figure out which one was used on both the 89 and 90, they should be the same.
bk240sx
Car: cars,hunting
no, same thing for the 89. i took the part off and cleaned it up but still idles like crap, and not one name written on it anywhere. im considering driving into a tree and getting some insurance money LOL. i ordered one and if its wrong ill just take it back and ask for the other one. but it takes two days each time so hopefully i get the right one first.
Blazin Hondas
Car: Working on stuff
Write down your vin #, call the dealer, get the part#, call the store and have them pull the part, then when you go in compare the parts, if its not the same pull the other one. It should be the same. I used to work for pepboys, in the parts counter...I had trouble all the time...I did this many times from the counter for customers. Good luck.
wanabe240esx
pepboys rules, call them, matter of fact
<---works there, hold on, ill get you your part
what did autozone give you for a price?
149.99 pepboys has a bunch in the INDY warehouse, take a couple days, but thats the only one we have listed, the zone screwed up
bk240sx
Car: cars,hunting
i got one from auto zone for 114 and it was the right one but my problem is still there just not as bad. next im replacing the TPS and if that doesnt work im gonna sell the car as is for like 1500$ cause i have 2 guy that want to look at it. only thing is i may miss doing waht i just did tn minutes ago.
pumping gas two cars of hicks pull up a berreta and a really jacked up ford yelling like a bunch of idiots and just being dumb trying to show off but they just look stupid. i start my cr give it a few little revs (to like 3k) and then pull out to the highway and do a perfect drift across the three lanes and contiune to burn em till about 40 mph. felt good.
bk240sx
Car: cars,hunting
thanks for the help though guys
