Dani-30 »
https://forums.nicoclub.com/dani-30-u41641.html
Sun Aug 20, 2006 5:43 pm
The "service engine soon" light is mislabelled. It should really read "check engine now" - that is, get a readout from your onboard computer.
Your Infiniti is not programmed to automatically remind you to service your engine at a certain mileage, or after a fixed number of miles since your last dealer service.
Below 2,000 rpm, only one tailpipe is open, and exhaust gases travel through an "S"-shaped snake of connected pipes inside your muffler that is three times the actual length of your muffler - so your car is extra quiet at idle and at low rpms (city driving). As rpms rise through 2,000 rpms (highway driving) an electronically-controlled valve inside your muffler opens and the second tailpipe begins to operate. Exhaust gases now vent through two parallel pipes and travel only a single length of the muffler before exiting the two tailpipes. This yields significantly lower back-pressure and higher horsepower. But it also makes the car (slightly) noisier....which is why the volume of your audio system is programmed to increase (slightly) as your engine rpms increase.
Neat, eh?
