Hey Nissan experts:
I have a slow engine oil leak on the bottom of my I35 air conditioner compressor.. If I park car, the oil leaks about 5 drops per day onto floor, so the longer parked, the more the leak. I cleaned the compressor housing bottom, restarted engine, and the oil slowly started leaking. I could see the drop forming on the bottom (see photo), but could not see the origin; I suspect oil is seeping down the mating surface of compressor housing halves from above (somewhere near alternator).
The oil leak is not near the oil filter / oil cooler/ or oil pressure sensor (those all looked dry). I recently changed both valve cover gaskets to fix this issue, but there was no change to oil leak. The front valve cover (above the alternator) does not appear to be leaking
Any ideas?
[img][/https://1drv.ms/u/s!AiZROxNQ3cBekBEcEPcny7RUPRqM]
