mikegmail »
https://forums.nicoclub.com/mikegmail-u163206.html
Tue Mar 22, 2011 8:34 am
HI,
Does anyone know to disconnect the electrical plug/wire harness from the ABS control unit? How do you pinch it or whatever to get it to disconnect?
The error code indicates a "short" to the right rear ABS sensor. I have the FSM and the wire color codes so I can check for continuity and replace wiring if necessary. Already replaced the sensor, but did not solve problem. Also, when I disconnect the abs sensor plug, error code is for open circuit.
Any suggestions welcome.
Thanks,
Mike
New Jersey
