depoautolights »
https://forums.nicoclub.com/depoautolights-u74721.html
Tue Dec 18, 2007 12:37 am
i own a 98 i30t and i put some 20" wheels which i have had on it since 05...took them off for 8months and put them back on, my car handles horrible...first my ball joints broke on pass. side and axle also broke and i fixed that..
now when i drive, it makes noises on the driver side like something is loose, sounds kinda like a spring going up and down, kinda squealing noise but not really loud...i have changed both struts still no change, im now thinking its the ball joints on the driver's side...also the ball joint on passenger side is loose so when i hit bumps you can hear the noises...does anyone have an idea if there could be any other possible thing causing the noise on the driver's side??
when i drive it just sounds like something is about to break loose or tear apart? im also suspecting transmission mounts so i dont know
p.s. i changed motor and transmission in the car (with one from a maxima if that will help)
