GerryO »
https://forums.nicoclub.com/gerryo-u56567.html
Fri Mar 28, 2008 5:39 am
Hi,
You are very observant. Probably not much help, but here goes anyhow. The good news is that any change has to be air, fuel, vacuum system or spark related.
Do you depress the accelerator at all when or immediately after starting the car and is it easy to restart, once it dies? How amny miles on your car/engine?
A normal cold-start for my J30 (simply turning the key) involves a very short cranking period, a louder engine sound at higher rpm for a short period until the fan clutch disengages, and so on.
I had the engine die once after starting it (and it took a while to slowly die), when I started it without the air filter and MAF connected for the first time after changing the timing belt, accessory belts, water pump, etc.
Simple things to check/replace would be the gas cap seal, the air filter and possibly the fuel filter, and for any signs of fuel or vacuum system leaks.
Q45tech makes a good point about knowing whether or not the Check Engine lamp is working/connected; does it light when you turn the ignition key to ON without starting the engine?
