arakami »
https://forums.nicoclub.com/arakami-u264982.html
Mon May 30, 2016 2:01 pm
I bought an i30 blindly 3 days ago for way to little, Drove it 45 miles, got only have a tank outta that, the next day it started stalling while driving, not starting, starting only when cold then running til hot, ect. all sorts of stupid issues, i checked here many suggestions pointed to the Crankshaft position sensor, it wasnt that, i had fuel i had spark i had everything i needed to make a car run, i thought. then i started taking apart things, this is when i discovered the EGR tube on the back of the engine was so gummed up, i had to used dental picks to get the crap out, i cleaned the top hole cause it was so clogged, Still no start.... finally 2 hours later i tried starting it, it came to life slowly and poorly but it came to life, i gave it some throttle and could here the crap in the tube get blown out. its ran fine and strong so far, im going to replace the entire EGR system but til payday i think i got it solved. If anyone has this issue and cannot solve it check the EGR tube, but also check the inside of the intake manifold where the IACV comes off, theres a little recess in there that gets very very clogged as well and that could cause all sorts of intermittent issues.
