I30 rough idle at start
mmike87
Car: 2000 Infiniti I30
Hello, I have a 2000 I30 with 112k miles on it. After sitting for a day or so, when I start the car the idle feels slightly rough. When I put it in gear, there is no throttle response, and this AM it stalled.
Once I get going down the road after about 15 or 20 seconds it's fine all day. Smooth idle and no issues.
Any suggestions? Thanks!
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
adjust IACV up a little, clean MAF, run some fuel system cleaner, and use premium fuel only.
mmike87
The MAF was replaced about 10 months ago ... can they get dirty that quickly?
mmike87
Well, jltibbs - you called it. The dealer said the MAF was faulty, especially bad at cold startup. There was a code set for the car running lean ("135% alpha" whaever that means), so I imagine that the rough idle at startup was caused by the mixture being too lean (as I understand it engines typically run richer when cold...)
I also got the full transmission flush service as well, and the car seems to run great and shift are a bit smoother now.
