bvehorn »
https://forums.nicoclub.com/bvehorn-u198646.html
Fri Mar 30, 2012 8:41 pm
OK, I've got a completely new cooling system... radiator, hoses, thermostat, water pump, and thermal transmitter. The fans come on when they should, the system holds pressure, and I'm not losing any coolant. BUT, my temp gauge still reads from half scale when cold to full deflection when it warms up. Except when it doesn't. What I mean by that is that occasionally it will indicate normal temperature, like it did before the engine overheated from the cracked radiator.
Today I pulled the instrument cluster and checked the resistance of the gauge. It read good according to the FSM (103 ohms A-C, 134 ohms B-C), and it reads good in diagnostic mode. The connector on the thermal transmitter (F25) looks like crap. I couldn't get to the continuity checks before it got dark, so that will happen tomorrow. But it seems like there's an intermittent short somewhere. Has anyone experienced this before? I just can't see where the problem could be, since the sensor wire goes straight into the main wiring harness. Hopefully I'll know more after the wiring checks. If anyone has any tips or suggestions, I'm all ears.
Cheers!
