luisgofarrill »
https://forums.nicoclub.com/luisgofarrill-u178237.html
Tue Feb 01, 2011 1:26 pm
Ok, I've been looking through the site for days now, and have gotten alot of information. Thanks.
I bought an Infiniti I30 about a month ago with a check engine light on. He told me it was and EGR problem. I pulled the EgR Valve, replaced it, and cleaned out the tube. Then I went ahead and cleaned the TB, and IACV, changed plugs and air filter. It still ran rough, so I ran some seafoam through it and it smoked like a siv. Now, when I'm in drive at a stop sign it idles down to 500rpm, enough for the check oil light to come on. If I give it gas, the check oil light goes away. Finally took it to get the codes checked and it said Knock sensor, O2 sensor (bank 2 sensor 1) and cylinder 5 misfire. I reset the codes, but the O2 sensor and knock sensor codes are still in. However, when I drive on the highway and rpms hit about 2000, it vibrates. Don't know if these are all related. I've also changed the oil and filter.
BAsically, where do I go from here. I've seen threads that say the KS could be a product of O2 sensor. I could possibly be misfiring, but the spark plugs look good, even after the seafoam clean. I've also seen that it could be the MAF sensor. So tonight, I'm going to clean the MAF sensor and see if it helps. Not sure if I should replace the KS or O2 sensor or both. Could I have an intermittant misfire on cylinder 5 that only shows when I get up to speed? Lots of questions, I know, but wanted to give as much information on what I'm seeing as possible. Thanks for any help you guys can give. I already feel 10 times more educated than I was a week ago just from reading this site.
