Maybe or maybe not. I never have successfully cleaned one and
"brought it back to life" but others on the website have
Try cleaning it with MAF cleaner -You can get it at Walmart
Liberally spray the wire inside the hole
You might clean the connector with it too
Use a little silicone dialetric grease in the connector to make it
less susceptable to water intrusion after cleaning
You can also surf the threads in this website for more info
or the shop manual below;
http://www.nicoclub.com/FSM/I30/1998_I30/ec.pdf
On page EC115 there is a flowchart to diagonse MAF
if you have a multimeter you could check the power supply
on the connector and see if the ground wires are tight.
