TKouT »
https://forums.nicoclub.com/tkout-u165270.html
Thu Jul 29, 2010 3:07 pm
When I am slowing down or at a stop, it try to stall. I have no check engine light and my tachometer fluctuates when I am idle. Sometimes before it stalls, It surges then drop to around 300 rpms. I notice today, that even through it didn't stall, my rpms drop drastically and fluctuated back and forth, and then went to 1000 rpms , which jerked my car ( I had my foot on the break).Also my tachometer floats between like 450 and 700 when I am idle, even through it doesn't stalls. What could be causing this and is it ok to 300 miles out of town?
I took it to a mechanic a little over a week ago, when my check engine light was on ( which through codes P0325 for Knock Sensor, P0401 for the EGR tube being clogged with carbon, and P1401, which said Throttle body Position Sensor) and I know he cleaned my throttle body, intake manifold collector, my egr guide tube and replaced my egr temperature sensor and throttle body position sensor. I took it back to him because it is still stalling. I cleaned my mass air flow sensor myself with rubbing alcohol and a q-tip, but it wasn't dirty. I have a factory service manual, but I have been told it is either my mass air flow sensor or my IACV, but my mechanic doesn't want to replace both of them because he says they will be throwing codes. Is that true? Is it safe buying theses parts on online or going to a junk yard and getting them? I have been reading that the MAF may not throw a code. I will drive it some more tomorrow and see if I can give a more specific description of the problem.
